- Feb 7, 2013
- 2,534
This morning I thought I would try to make use of some cutter teeth from an old carbide tipped table saw blade. At first the plan was to desolder
the carbides and affix them to some steel. On second thought I decided to cut some pieces out of the saw blade and use them as the
cutter tool to fit in my cut off holder. One can change the geometry by cutting out the cutter at various angles. I made one just for
fun to see how it will perform and may make several more as the need arises. I ground the cut out piece of blade to 3/4 inch wide to
fit the cut off tool. The carbide measures slightly under 3mm wide and the saw blade itself is probably 2mm thick so there is plenty of clearance. This cutter looks like it will
have a little positive rake but that can be easily changed by the angle used when doing the rough sawing or some grinding on the top face of the carbide.
