SAFETY CONSIDERATIONS with machine shop work!
HMF
Site Founder
Administrator
Sep 22, 2010
7,222
MIT http://electron.mit.edu/~gsteele/mirrors/www.nmis.org/EducationTraining/machineshop/safety.html
  • Safety Glasses
    EVERYONE MUST WEAR SAFETY GLASSES IN THE SHOP.
    Even when you're not working on a machine, you must wear safety glasses. A chip from a machine someone else is working on could fly into your eye.
  • Clothes and Hair
    Check your clothes and hair before you walk into the shop. In particular:
    • IF YOU HAVE LONG HAIR OR A LONG BEARD, TIE IT UP.
      If your hair is caght in spinning machinery, it will be pulled out if you're lucky. If you're unlucky, you will be pulled into the machine.
    • NO LOOSE CLOTHING.
      Ties, scarves, loose sleves, etc. are prohibited
    • NO GLOVES
    • REMOVE JEWELERY
    • WEAR APPROPRIATE SHOES
      No open toed sandals. Waer shoes that give a sure footing. If you are working with heavy objects, steel tes are reccommended.
  • Safe Conduct in the Shop
    Be aware of what's going on around you. For example, be careful not to bump into someone while they're cutting with the bandsaw (they could lose a finger!).
    Concentrate on what you're doing. If you get tired, leave.
    Don't hurry. If you catch yourself rushing, slow down.
    Don't rush speeds and feeds. You'll end up damaging your part, the tools, and maybe the machine itself.
    Listen to the machine. If something doesn't sound rigth, turn the machine off.
    Don't let someone else talk you into doing something dangerous.
    Don't attempt to measure a part that's moving.
  • Machining
    IF YOU DON'T KNOW HOW TO DO SOMETHING, ASK!
    BEFORE YOU START THE MACHINE:
    • Study the machine. Know which parts move, which are stationary, and which are sharp.
    • Double check that your workpiece is securely held.
    • Remove chuck keys and wrenches.
    DO NOT LEAVE MACHINES RUNNING UNATTENDED!
    CLEAN UP MACHINES AFTER YOU USE THEM!
    A dirty machine is unsafe and uncomfortable to work on.
    Do not use compressed air to blow machines clean. This endangers people's eyes and can force dirt into machine bearings.
