I need to cut the bottom off a 22 ga. stainless steel water bottle. The bottle is about 2.75" diameter. I wanted to build a fixture to hold my 4.5" angle grinder to the bench, mount a 1/16" Norton cutoff wheel, then perform the cut by holding the bottle against the bench and rotating the bottle (with safety gear on of course) as I bring it into the wheel.
In the picture, which is the safer cutting configuration, wheel cutting down or wheel cutting up? I'm thinking up is less likely to jam and buck. Right?
Mark S.
Mark S.
