- Mar 24, 2016
- 100
I just got through watching Rudy Kouhoupt’s video about using the Atlas Horizontal mill, and it left me with a fair number of questions.
1) The drawbar he used was a rod, threaded at both ends and using a cylindrical spacer. Did he just make that as a substitute for the original or was it some sort of special alternative, or improvement or whatever? It did look kinda handy to be able to start the rod into the back of the MT while it was off the machine, then push the rod through from the front.
2) The arbor he used had no notched collar for the driver that Atlas provided. Does the arbor work just as well with just the resistance fit of the #2 MT taper or should I always use the specially made arbor with the notched plate engaging the driver? He was taking some pretty aggressive cuts, but it was in aluminum.
3) He seemed to feel like the vertical brace in front was necessary to get sufficient rigidity… so much so he built one for himself. With that honkin’ big overarm, is it really all that necessary?
Mr Kouhoupt’s reputation bordered on the mythical, but I am a little bothered by the seeming discrepancies between what he said about the Atlas and what I seem to be finding in the original instructions and discussions here. Do any of you actual Atlas users want to chime in here?
