I am changing out the X leadscrew on my Bridgeport to do away with the defective geared power feed. A friend had this apparently new leadscrew, the right length, sitting in his shop. He was not sure where he got it or how long he had had it. It was wrapped in fabric but had some surface rust. I have cleaned it up with Evaporust as far as it will go, The threads on one end have some rust you can feel on the top of the threads. the other end cleaned up OK. Not sure where the contact and wear area is on these. Can I use some 600 grit and clean this up to preserve the nut? This would not damage the edge contact area of the threads. Is the diameter critical, or just the edge screw wear?
