- Dec 9, 2012
- 7
This bench top mill has a round riser column with a keyway to keep it lined up and not rotating. The PO seems to have filed the (overarm) key down to allow the column to move a little bit more easily up and down giving rise to my problem. I need to replace the key to stop the head from moving side to side. There is about .005 - .007 clearance now between the key and the slot. The file marks can still be seen on the key.
I have to replace the key with one sized for the slot. I'm assuming the key is mild steel???
Can I, or should I, replace it with one made from half hard brass, or mild steel, or might it be cast iron?
Thanks, Ron
Thanks, Ron
