4
4GSR
Forum Guest
Register Today
I've taken a small RPC that's been in the family for several years and used to power 3 to 5 HP motors. Currently have this set up with a 3 HP pony motor and trying to start a 2 HP that is located about 56 feet from the RPC. The motor I'm trying to start is under somewhat of an load. That is a variable speed belt drive on my lathe. When I hit the start button on the lathe, the motor wants to run but doesn't gain full speed and finally trips the heaters on the starter. I've double checked the motor leads to make sure they are connected correctly and they are correct. I'll have to open up the RPC controller and get the capacitor ratings, I will say they are small compared to the others I've used in my past.
So my first question is , Do I need a larger poney motor? Like a 5 HP?
Nest question is, Do I need larger capacitors for the 56 foot run of cable between the RPC and the lathe?
I can move the RPC closer to the lathe but will require some rewiring of the heavy cable supplying power to the RPC. Open for any suggestions. Ken
