I discovered something as I was making a rather intricate part the other day. Thankfully I did not botch it, but it was skinny close. Turns out a 1/4" (=0.250") diameter fine tooth roughing end mill (Asian) measures 0.255-0.256" in actual diameter. I was doing work on a rotary table where I was offsetting by a radius using DRO. I gave myself what thought was a healthy allowance to clean up to final dimension with a regular end mill after the rougher. Only to discover the regular end mill was cutting air because it was 'on spec' at 0.250" +/- 0.001" I haven't gone back to check my other rougher EM's but might explain a few past mysteries I had chocked up to setup.
Is it reasonable to expect roughing end mills to be within similar diameter tolerance as regular end mills, or maybe that comes with brand name tooling? I just naively assumed they would be pretty close to reference size.
