I thought I'd broken my variable speed bandsaw a few days ago - but apparently just kicked it into neutral. Having already found a problem with one of the blade guides I thought I'd take care of some nuisance bits. I need to make a new knob / handle for the hi/lo speed range lever, a new throat plate, a knob and latch mechanism for the lower wheel door, and of course, fix the guides. Which brings me to my question: Are roller guides, like those sold by Carter, worth it on a metal cutting saw? I currently have steel blade guides with a bearing in the back (the back of the blade bears on the flat portion of the bearing). If it's worth it, what sort of advantage should I expect?
TIA,
GsT
TIA,
GsT
