- Nov 19, 2011
- 966
was wondering if they make a chart that tells you the rod size that you would need to cut a known thread. i want to be ably to make my own bolts minus the head or threaded rod:thinking: i know i'm thinking again lol
ty tony understand, you cant take a 1/4 inch rod and thread it for a 1/4 nut cause the rod is just a tad to big so you turn it down to the minimal or highest:biggrin:The specific major diameter limits are given in Machinery's Handbook for most threads. Generally it's the nominal size with a minus only tolerance.
ty mayhem seems anther tool is in order:biggrin:If you wanted to make a 3/8-16 bolt, you would start with (or turn down to) a major diameter of 3/8". Using a nut or thread measuring wires will tell you when you have cut the thread deep enough.
The tap/drill chart Ed posted will tell you the size hole you need to drill in order to accept a particular thread diameter and pitch. The size of the hole can be varied to set the amount of engagement.
Ty billyG going book hunting:biggrin:The book specified is the Machinery's Handbook. You can get used ones on Ebay. This book has been the Machinists right arm since its first printing. I believe the newest edition is the 28th. The first Edition was printed in 1914 I believe. This book will prove invaluable to you. There is a guide that goes with it that explains how some of the numbers are arrived at.
"Billy G" :thumbzup::thumbzup::thumbzup::thumbzup:
sounds great, let me know how to get the funds to you. again ty:biggrin::biggrin::biggrin:If you did not go for that one yet don't. It's too banged up and won't last in the shop. I have a 25th edition in large print. See your PMs.
