Just purchased this Frankenmill. Rockwell base and a Rusnok ST head. I am a little concerned about how rigid it will be with kluged mounting. Flat plate welded to the Rusnok mounting post. I guess the Rusnok St was made to be mounted on a horizontal mill as a convertible head. It came with the vise , a set of milling collets and holders. Also had a DC variable speeder motor. Barely made it into my workshop space, but moved it with the head off and a set of roller jacks.
A couple of easy questions.
On the Rockwell base, was the head mount made to be taken off? It looks like there is a keyway on the top to align the head to the top of the base.
Should I tear this thing down or try it out before doing anything.
Thanks
Eric
Thanks
Eric
