B
Buffalo20
Forum Guest
Register Today
As my mill hasn't arrived, hopefully someone can answer a question.
As the mill has a small base, how stable is it? I have a Atlas/Clausing (Johansson) mill base that was turned into a drill press, while similar in size the base/cabinet on the Atlas seems a lot bigger. Because of the narrowness of the base, I wondering about side to side stability.
What have others done to make it more stable.
The other 2 mills I have are setting on a super heavy duty plastic pallet, with a 1/2" steel plate, fully covering the pallet, sandwiched between the mill and the pallet, with the whole assembly bolted together. Not only are the mills very stable, but this also raises the whole assembly 6" and makes them easily moved with a pallet jack.
