Guys,never used a turret on a lathe before so what would be your preference?Using a tail stock or turret?This one does have some issues which I hope I can fix.Problem being where the drill chuck is when I index it in position it has some play in it.So I need to find myself a manual on how to adjust this if there is any adjustments that can be made.I hope to also find a parts list so can see what may be causing the play when drill chuck is in position.Any advice,yea's/na's Yes I do have the handle I remove it cause this thing is heavy as can be.
