Rockwell 11" lathe speed indicator
homestead
Jan 17, 2017
25
Hey Rockwell owners,
I have an 11" Delta (Rockwell) lathe which I have used for several years, but never fixed the variable speed indicator inside works which move what's on front of the cabinet. This is a hand wheel rather than a lever changer. I cannot find a pix of the mechanism which connects to whatever inside the cabinet..I know I will have to make whatever it is, but do not know that to make! I will try to post a pix of what is there, but it appears that a worm shaft and its connection to the variable works is missing. Any pics of that connection works would be appreciated.
Thanks
homestead
Does this look like what you need? If so I can give you pics and measurements.20171004_153139.jpg
Yea, my whole connection and reeves drive is all there and intact, I just checked. No belt, but I don't think you need that.
Richl,
Man, just what I needed! I hope you didn't throw your back out getting these pics! Seems I'm missing three parts. I thought from what I had that the gear ran off a worm , but it is a rack! I can make all the parts now.
Thanks for your help--couldn't have known without the pics! This lathe is small, but works well in a home shop.
homestead
Mine is 11x24, I really need to get it working. Thanks for giving me a reason to look at her a bit more closely.
It does look like a very straight forward setup for you. If you need anything else, feel free to ask
I have fixed my spindle speed indicator--now I am working on a graphic for the threading chart---the chart on my lathe is unreadable. When new, the chart was all black screenprinted on a silver plate--no red at all. I have found a jpeg of the plate on the web, but cannot read the longitudinal numbers under the thread pitches. Does anyone have such a thread chart and could one post a sharp pix of the chart. When I finish the thread chart graphic, I will post it to this thread for others to use!
I'll be back in the shop tomorrow, I'll check to see what I have. I'll try to cleanup mine and take the best high res pic I can. If mine is in decent shape I can grab a full resolution picture with a digital camera, a Canon 5d mk4 30 megs. If needed.
richl,
From your previous pics, your lathe has the red and black thread chart. Mine has the all black chart. I have completed a graphic of my chart based on some longitudinal feeds which had to be calculated as I could not read the existing chart on my lathe. I will post the chart soon.
