- Jan 25, 2021
- 50
Lots of Loggers are bringing me the big Jib boom And Mainlift cylinders.....the beautiful welds are leaking along the edges of the weld beads!!! Incomplete fusion of the weld bead to the parent metal....I blast it out with the air carbon arc rod....grind deep....preheat to 275 or so...6010 root pass, 3/32 -7018 hotpass 1/8 fill pass then a 1/8 capping pass.....on the much thinner bucket cylinders you have to be careful because these thin barrel cylinders distort badly..... more weld is BAD!! I usually tig weld the root.and put a lay wire cover pass over that with good ole ER70S2
