Picked up a new Rikon 15-400 metal saw and I'm wondering if my expectations are too high or I just got a lemon. Saw them on LMS so figured they were well regarded and a step up from some of the entry level saws.
However I've had no end of problems with it including:
* Cracked power switch housing when arrived(as best I can tell the auto-shutoff contacted the switch in shipping). Ordered a replacement part so that's fixable.
* Pretty significant vibrations when running(motor vibrates 0.5-1" under power), top wheel is balanced, and motor runs freely so I suspect something in the gearbox/pulley.
* Blade guard/table screw were *tight* and rusted, I got one free but the other stripped out on me. I'm soaking it in penetrating oil with the hope that drill + extractor will get it out.
* Doesn't cut stock straight(this just seems like an adjustment that I haven't had time to get to yet).
Wrote their tech support over two weeks ago heard exactly zero back from them. I'm hoping I don't have to change the blade before I can sort out the blade guard since it requires removing that before you can change it.
Anyone else had similar issues? I get needing to setup/dial in a machine but for $700 I was expecting to run into less issues.
