Rfq Aluminum Welding/lathe Work
AxeMaker
Aug 16, 2016
193
Hello,
I am northeast GA. (North West Gwinnett county) and need to get a quote on the following;
I have the following aluminum that needs to be turned and welded;
1 - Aluminum tube 5" I.D. x 24" Length x 3/8" wall.
2 - 5" O.D. Diameter x 1/4" thick round plates with 1" bore (already turned and true)
2 - 3" long aluminum tube x 1" I.D. x 1/2" thick wall
In whichever order it should be done;
I need to have the 24" tube turned true on both the diameter and ends.
I need to have the 3" tubes turned true on both the diameter and ends.
I need to have the two round plates welded on the inside ends of the 24" tube and then the 3" tubes welded on the round plates.
This will be part of a drum sander project and, of course, this will be my sanding drum. It will be spinning up to around 2500 RPM so its important to get everything perfectly true.
I can be reached here on the forum or ar15dcm@charter.net
:anyone:
I can pay via PayPal or Bank Wire Transfer.
The guy who made the plates quoted me $250.00 to do everything.
Anyone want to make some money?
:dollars:
