- Nov 24, 2013
- 268
Since I haven’t been able to decide which vise I should buy, I have revised my home made vise using this time a Swivel Base 1/4"-20 nut I noticed on the KBC tools catalogue.
Now the vise is sturdier and I have glued sandpaper at the bottom / top pieces where the 1”x 1” aluminum block sits for a better grip. The only problem I have, actually an inconvenience, the piece where the swivel base nut rest is loose since I haven’t been able to figure a way to secure it in place. This means when I loose the bolt holding everything together the aluminum block and the piece under the nut are falling off.
Do you know a way to secure the nut or perhaps I’m using the wrong nut?
