gerald---if you look closely at the picture i sent --you will see a machine screw protruding from the reversing mechanism. this screw is what holds the ''knob '' onto the reversing mechanism shaft. as i remember it's an 8/32 thread. yes it's sheared off--you will have to center drill and wedge something tightly in center of drilled hole to remove the broken mach. screw. once a new screw is inserted --that is really all you need to operate the power feed up and downward ---it also has a neutral position. you can make a new knob at a later date--now as the screw is moved towards and away from the operator you should feel 3--very slight ''detent'' positions. up feed-- neutral-- and down feed. the inner shaft which contains the ''screw threads also changes the feed gear position ''it has 3--grooves around it's outer circumference --they are contacted by a spring loaded ball as the shaft is moved inward and outward. it's a very ''soft'' contact and the shaft moves a very short distance between it's 3-- gear locations. the ''clutch'' is that handle to the left of the machine and should disengage, by itself ,when it reaches the top of the quill travel or when it has proceeded downward to a limit you can preset --before you begin drilling downward. hope i didn't confuse this too much--writing instruc. books just is not my thing. if you have more ques.--fire away--there are lots of people on this site who are willing to answer same and remember it's suppose to about ''fun''
) re steve in mt.
