- Sep 22, 2010
- 7,222
Is that your unit pictured or the "someone else's" you mentioned? If that's yours, did the motor run before you took it apart? Cleaning is pretty straightforward (my hands feel greasy just looking at those pictures LOL) You'll have to check the bearings, gears and brushes. The comutator should be carefully cleaned (that's the part the brushes press against) and checked for wear, skimmed on a lathe if necessary and undercut. A motor shop should do that last part.
Mark S.
