I know reamers are cheap so its not commonly discussed how to resharpen them. I already have a basic understanding of how to resharpen the leading chamfer as this is commonly done and what does the initial cutting but what I really want to know is how to resharpen the flutes. I am aware that this will reduce the size of the reamer and that's actually what I am after. I have searched high and low looking for common margin and land angles of the radial flutes. Machinery's Handbook and the like don't seem to cover it unless I am just not seeing it. Does anyone know where I might find these angles and do the angles change as the reamer gets larger? I would assume the angles change for larger reamers as they do for end mills. I have the tools to resharpen straight and spiral flute reamers so thats not an issue.
I am starting with a 5/8" straight flute reamer. Is there a good way I can measure these angles myself?
