I have an Enco 12 x 36 and the motor has always been prone to acting up with strange buzzes, hums and sometimes refusal to start. Lately, there has been a strange hum while running at speed. I think it is time to consider repowering.
The current motor seems to be 1 1/2 hp (7.11 Amps, 220). 1140 rpm. Pulley sizing gives 1/2 spindle speed when the belt is on the small motor pulley. Max spindle speed is 1200. Here are my issues:
HP requirement. I have a 1 hp DC motor that I am considering using. I always thought the lathe had excess power and the 1 hp would be okay. But when I upgraded the 4 jaw chuck, the motor really had to work to get up to speed on the higher speeds. The old chuck weighed 32lbs, the new one 38. I know the DC motor would start at zero rpm, so starting effort is not critical, but it does give some insight as to how hard the motor is working. Anyway, any thoughts or experience on power requirements?
Motor type.
Replacing with a 220, 1140 rpm motor seems a waste. They are expensive and really have little going for them other than they power the lathe at the correct rpm.
DC with PWM vs. 3 phase with VFD. I have zero experience with both. What's to consider?
Motor rpm.
The DC motor I have is 2400 rpm so I could belt it up using the small motor pulley and have a max spindle speed close to OEM. Three phase with VFD is a different ball game as the speed variation is plus or minus motor design, so I see no real value in an 1140 rpm three phase. I'm thinking an 1725 rpm motor would work better. Maybe 3450?
Bill
Motor type.
Motor rpm.
Bill
