- Oct 2, 2020
- 88
I'm considering purchasing a Taig mill in the near future but one of the biggest turn-offs is the rotating Z hollow square tube frame. Looking at the exploded view, it appears you might be able to just bolt it onto something L shaped? Off hand I was thinking fixing two granite surface plates perpendicular to each other. I've also seen some bracing/turn buckles used to add rigidity to the Z. Has anyone tried filling the column with concrete (like Taig does it's lathe) or just tacking the where the column swivels on the base?
