Hi everyone,
I have a 4x6 bandsaw that is leaking gearbox oil around the shaft that the bottom wheel is attached to. The previous owner had grease in the gearbox, and after using it for awhile I cleaned it out and put in gear oil. Well, I quickly discovered why the other guy had grease in it, because it started leaking oil very quickly.
I took it apart today to figure out where the problem is and found a severely damaged oil seal and a plastic bushing of some sort. The dimensions are marked on the oil seal 35mmx15mmx7mm and I've found a couple sources for that, but I can't find any info on the grey plastic part seen in the pictures below. I've looked at manuals for the various 4x6 saws like the Harbor Freight, Grizzly, Jet, etc and they all seem to have similar parts, and list this item as a bushing or spacer, but none list any dimensions.
Has anyone here ever replaced this part? Mine is so damaged it's hard to tell the shape and size. It looks like it might have been tapered to fit into the oil seal, but it's hard to tell for sure. I've been searching online most of the day more details about these parts, but haven't found much. So any info or advice would be much appreciated.
Thanks.
Thanks.
