- Nov 29, 2014
- 20
Replacement of damaged handle
As I was moving my mill to a new mount I bent/broke the hand wheel handle.
Decided to make a replacement handle. The original handle was made out of plastic (seemed to be similar to Bakelite) I’m going to make the replacement out of aluminum. Also there are two other same size handles that are used on my mill and lathe, decided to make 3 new handles and replace all of them.
Did have a small problem finding a M8 – 1.25P X 60mm long Socket Head Cap Screw that did not have the threads cut all the way up the shaft. I wanted about 25mm or more shaft with no threads for the new handle to turn on. After going to a number of hardware stores I found some with no threads all the way up the shaft, there’s no standard on this it’s just how the bolt manufacture wants to make them.
I did a quick drawing of the dimensions of the handle I wanted to make. Also listed on the drawing are some speed and feeds that I used to make the handles, they appeared to work good for me. I’m teaching my self machining on my small mill & lathe, still trying to figure out what speed and feeds to use with my limited machines.
The finish on the new handles is 400 grit sandpaper, brushed finish.
