To be clear, I do NOT want to go full CNC. I wonder about losing the gears and using a stepper to drive the main gearbox, which looks like it has 1:1 as an option. Maybe even using a pair of gears for reducing the required torque. There's already an RPM pick up so I could use that for timing or add another hall effect sensor. For bonus points, add a timing system for metric threading and auto stops at the ends of travel via limit switches or input from a DRO scale.
All the controls would still be manual, but I could easily switch turning speeds and thread pitches. Sort of like an electronic QCGB.
The idea seems simple enough, but I don't see it done. It would also make a nice indexer if I had it drive the spindle instead.
Random musings from what passes for a brain in my head...
