I recently bought a SB heavy 10 lathe abd with it came a 6" Buck 3 jaw chuck D1-4 mount on it
I disassembled the chuck to assess and clean and lube it and found one of the master jaws has the
last segment/thread broken off, so the unit still works on small diameters but when you get the larger
pieces it has issues. Can a person just buy or order a new set master jaws or are they fitted to the main
body and one set from another won't work properly, this is an older unit say 1980 era with the kind of jaws that
the top unbolts to reverse or be replaced by soft jaws, its the main piece under that that has the broken
part, the scroll itself is fine and only one jaw is damaged but that might be enough to make the unit junk?
