This may be common knowledge to some but was informative to me and confirmed past experience. Here is the story.
A friend who ownes a quality assurance lab was asked by a large manufacturer he tests for what was the best method of repairing shaft and bores to tighten bearing race fit without major machining. They tested bearing retainer, prick punching and prick punching with retainer (I had never thought of that). In 10 tests of each method 5 testing inner races and 5 testing outer races the results were.
punching only. at 30-40% of max load bearing fit became loose and back to close to what was started.
retainer fluid. 2 inner races and 4 outer races survived 100% others became enlarged to varying degrees.
punching and retainer compound. all survived 100% load for 50 hrs.
This was a very small scale test and was of limmited focus but the trends should scale. I can't provide specific data because I wasn't the one the test was done for and don't have access to it.
Hopefully this helps someone. I know how I will performe guicky fit repairs in the future.
Roy
Roy
