- Apr 16, 2019
- 746
I belong to the Blue Mountain Gas&Steam Engine Association ( Jacktown ) some of guys are working on a Cletrac crawler , the PTO pulley has fallen apart , it was some kind of laminate material with a cast steel hub I offered to make a wooden one . I cut 4 pieces of pine for each half used a 4” hole saw to get the center hole ,then glued together . holes were drilled for the 4 cast lugs in each half . Used a router to remove the mating sides for clearance of center of the hub . Drilled through holes and bolted them together. I made a tapered shaft with a 3/8-16 threaded hole to hold the hub/pulley assembly. It was too big to clear the carriage of my Clausing 5914 lathe so I used my homemade boring bar and holder to cut the OD . This will only be used as a display but I believe it would hold up to limited show use
