- Mar 8, 2014
- 41
Hi Everyone. I will be grateful for any advice about removing the spring base from the headstock of this milling machine. The spring base houses the return spring for the vertical spindle. It apparently is retained in the headstock by three small screws, described in the manual as setscrew M8-1.25 x 16. I have removed the cover spring and motion mechanism on the other side of the headstock.
As shown in the manual, there are three threaded holes eqi-sapced around the outside of the spring base close to the headstock casting. The spring base has some rotational and sideways play, but is held in place, apparently by screws in the three holes.
I have tried every instrument screwdriver and allen key that will fit in the hole, down to extremely small sizes, but none of them engage in whatever is in these holes. Every tool seems to bottom out at about 2 cm, so nothing is entering an Allen key hole in the end of a screw.
Has anyone removed the spring base on one of these machines? If so, can they let me in on the secret of how to remove it?
I should mention that the purpose of removing the base is to reposition the spindle lowering splined shaft in the rack on the spindle, to stop the handles clouting the table when the spindle is in the fully up position.
Regards John Poxon
Regards John Poxon
