- Jun 15, 2017
- 585
I thought I was saving money, removing and replacing my tractor's steering cylinder by myself. Then while I was installing it, the piston rod put a hole in the front gear case.
The used gear case I bought to replace it has an oil seal and old gaskets stuck to it. It's aluminum. What's the genius way to remove them? Maybe a pressure washer? I know using a razor on aluminum is stupid.
