- Dec 3, 2016
- 11
I have a new (to me) mini mill that uses MT3 collets. They seem to be quite hard to remove . What I do is to loosen the drawbar a couple turns and give it several hard taps with a hammer. The collets then come loose and I can remove them. The collets are clean and dry, as is the spindle bore. My question is, should I apply a small amount of lube to the collet before using it, or is it best to use it dry and live with the stubborn removal. I only tighten them up to what I would describe as snug, not overly tight.
Thanks in advance
Paul
Thanks in advance
Paul
