I have a frozen pin rusted, seized in a cast housing. The pin is hardened, 1/2 inch in diameter. The cast housing is about 1/2 inch thick.
I have been taught to heat the housing so the hole expands and remove the pin while the housing was hot. The threads I read said to heat the pin and let it cool, then remove it. Which is correct?
I was not going to heat the housing beyond 500 deg F.
