- Oct 7, 2020
- 94
In the 728-VT manual, the section called "Uncrating and Moving the Mill" is immediately preceded by a small section called "Removing the Drawbar". It never explicitly states that you're supposed to remove the drawbar before attaching the engine hoist, lifting it from the crate, setting it on the stand, etc. However, the fact that the instruction for removing the drawbar are on the same page, and immediately before, the section on moving it makes me think maybe you're supposed to remove the drawbar first. Does it matter if you do or don't?
