- Oct 19, 2020
- 160
Thanks to all the members who replied to my posts with my newbie questions. Your experience is very helpful. I know that I have been very slow in my progress but I have limited time and am probably overly cautious. I might note that I am enjoying the journey, reading the "How to Run a Lathe" book and finally understanding what some of the tools my father left me are for.
So, I have become comfortable enough with the lathe to finally turn it on. I wheeled it over to the only 220 outlet I had in my basement and got ready to plug it in. But alas, the male plug on the lathe did not match the female outlet where my dryer is plugged in.
Now I have decided it is time to make room for the final resting place for my lathe and to run a proper circuit breaker dedicated to the lathe. The picture where you see my drill press is where I intend to put it. An advantage of this location is that it is close to my breaker box so I will have easy access to the power.
I am wondering if any of you could recommend what amperage of a 220V breaker I should use? The motor is a Reliance 3 phase 1/2 horse power. I will be using a WNY Phase Converter & Supply model SC01 to convert it to run off of 220V household power. I have tried multiple times to get this info from the phase converter company but have not received a reply from them.
Thanks for your input.
TwoOldVolvos
P.S.
You might notice on the lathe picture that I have installed the Aloris tool holder that I purchased with the lathe. I needed to get a proper T nut that fit my compound. I purchased one from Rich Brown (330.723.2890) that fit nicely. I also had to run a 9/16 18 die over the T nut end of the stud to repair some damaged threads. Now to find a few more tool holders. I have only the AXA-1 at the moment. I didn't realize how expensive some of the tooling can be.
TwoOldVolvos
P.S.
