- Aug 20, 2024
- 44
This is a follow on to my earlier question re: how much torque does is take. I posted basically the same question in the general forum and got no responses, but figured someone that's done a CNC conversion might have some answers.
So I have a Grizzly G0619, and as everyone probably knows, cranking that Z axis handwheel is stroke inducing. I've already done a table power feed using a stepper motor, came out great, and now I want to do the same to my Z axis. I found pics on another forum that look perfect, I just need to machine some motor mount brackets that will bolt down with the column bolts, add a mounting plate, then replace the gear on the bottom of the lead screw with a cogged gear for a timing belt. The stock setup has a 2:1 gear reduction, but I selected a motor that should have plenty of torque to run this at 1:1. Assuming it will, is there any reason to still run a reduction? And is the timing belt the best option, or should I look at something else? Thanks!
Dave
Dave
