Need a tool for internal threading of 316L seamless tube. Generally about 1/2" deep into a .900 - 1.120 hole. Tried grinding out of a HSS blank & a brazed carbide bit, but didn't get good results with either. Will be making 28 tpi mostly.
Anyone recommend a good threading bar or indexable tool for it? I don't really get the LH/RH part of it when I look for tooling. I plan to cut these feeding from the right towards the headstock with the tip of the tool facing me. Not planning to run in reverse with the tool tip facing away from me cutting on the far side of the stock.
