Yes!
Or break first time use it!! They do look pretty flimsy!!
The ones with the handle and extra bits that go roundy when you twist them.
That look like a re-bar wire twister I used back in '62 when working on a bridge crew on I-80 near Iowa City??
Handle includes built-in safety lock and accepts all SHAVIV B-series blades. B10 blade is made of high-speed steel for use on steel, aluminum, copper, and plastic. MJM National is an authorized Shaviv Distributor.
I like the whirlybird types for cast iron and aluminum, but if I could only have one deburring tool it would be the good ol' tri-knife. The tri-knife gives the best control, does better fine work, and works on everything in the shop. Simple, too!
