- Feb 1, 2020
- 3
I bought a used craftsmen bandsaw model. 108-22921. it had no tire on the drive wheel so I replaced it now the band doesn’t want to stay on . Also when I was removing the top half of the saw I must have wiggled the wrong way and broke off two teeth on the nylon gear but I repaired that by cleaning the gear and putting in two part epoxy then after a couple of minutes I pressed that gear into the other to copy the pattern IT WORKED...but the band still wants to run off the wheels. Any ideas?
