Received one of the new boards yesterday.
Rob
Nov 19, 2011
332
I received one of the new boards yesterday and installed it today. When I first put it in and turned it on the tach did not work. After looking at the wiring I discovered that I had reversed the pins on the connector in my old board. I used the same connector as the new boards when I installed the tach on my other one but as mentioned unfortunately looked at the connector pin numbers in reverse. Got out the soldering iron and everything is up and running and I did a recalibration on the new one.
