Rebuilding Kohler 241S Carb
racecar builder
Dec 19, 2011
459
small engineers
yes. i am waiting on my can of Mac's carb cleaner from NAPA.
it's the Kohler carb not the other carb.
any tips for rebuilding these?
might want to run Nitro Methane through it later!:)
Have A Nice Day!
the only 2 real tips i can give you is to soak a cple of days prior to rebuilding and check the shaft play if there is any play at all it is very hard to set them:thinking:mac
woody
shaft play! ah ha!
i speet on loose shaft play!
now watch me end up with it!:)
are you sure you know which carb i mean?
i was ready to get the manual out!:)
this isn't like the inboard motor and transmission thing again? is it?
Have A Nice Day!
woody!
opened the manual and it was right there!
'my ally is the force!'-Star Wars
Kohler carb and Walbro carb.
mine is Kohler one.
i'm serious about mixing Nitro Methane with this sorry old 93 octane unleaded!:)
Have A Nice Day!
it might help if i had a pic, most are kinda built the same unless you get into the newer stuff then you got that smog crap on it, that bad when you got a catlectic converter on a lawn mower lol:biggrin:mac
it might help if i had a pic, most are kinda built the same unless you get into the newer stuff then you got that smog crap on it, that bad when you got a catlectic converter on a lawn mower lol:biggrin:mac[/QUOTE actually would like to see pic of whole engine lol:biggrin:]
manny
'i'm getting that old feeling again!'
here are pic's.
about that later carb stuff.
you're off and running, but nobody lateraled the football to you!:)
this is the old stuff here!
Have A Nice Day!
ok thats just like mine is that rust in the throat, if it is you may have a problem with that as a core rebuild, if it is get back with me i prob have a good core you can have have:biggrin:mac
mr woody
that is cutting it close about
difference between 'Kohler' and Walbro carb.
Kohler has high speed mixture jet on top.
Walbro is 'fixed jet'.
here are pic's.
Have A Nice Day!
alot of the walbro carbs were used on statinary engines , generetors pumps chippers but when they needed to have a throttle up throttle down the used the other like for tillers riding mowers now they did this in the earlier yrs so this dont always hold true in each one:biggrin:mac
