- Dec 28, 2021
- 9
Hi.
I am very slowly reassembling The KR-V2000 BP clone that I bought recently. I had to disassemble it to get it home.
I am spending a lot of time trying out various combinations of washers, shims and spacers and not being quite sure I'm doing things right.
It seems that on the Y axis, the backlash in the movement of the saddle is set with the shims in the handle - those between the handle and the power feed gear. Am I understanding this correctly? The end-cap stops the leadscrew from actually unscrewing out the front of the machine, but it still screws in and out until the ideal amount of 'stuff' is fitted to the outside of the shaft - the bevel gear of the power feed, some shims, washers, and the handle (which in my case is those safety-handles).
If I don't have the ideal length of 'stuff' on the outside, then I have a ~1mm gap there, and turning the handle simple takes up that space as the lead screw moves back into the machine.
Is that correct? There's nothing actually holding the leadscrew in place at the rear, so I can't see it being any other way.
Unless I am supposed to use some sort of spacer or shim between the screw and the inside of the end-cap, so that the screw is up against the back of the machine or something? but I don't think that's right.
