- May 27, 2016
- 3,479
There are so many types..
I guess what makes a "hand reamer" vs "chucking reamer" is the provision of flats to get a spanner in there, but here, the question is about spirals. I get it that a reamer with straight flutes is probably OK, and with spirals, it's better, but what is the wisdom about the direction of the spirals?
Here is what I mean. This is a right-hand cut with left hand spirals.
![RH cut - LH spiral.png RH cut - LH spiral.png](https://www.hobby-machinist.com/data/attachments/325/325352-bc18254996c96a31ad1ccd0e582bbbb5.jpg)
Then, you can get them get them go the other way. Right-hand cut with right-hand spiral - unless I mistake, and the whole thing cuts anti-clockwise!
![RH cut - RH spiral.png RH cut - RH spiral.png](https://www.hobby-machinist.com/data/attachments/325/325353-33100d70f1af5c255933ef375a5f30cc.jpg)
Of course, one can get straight flutes. I guess they cost less to make, but I have my doubts about this deal.
The whole set of 10 pieces 3mm thru 12mm in H7 grade can be had for £14.99, which converts to $21.13. Also, they seem "short", which might be a good thing in a mill with not much Z-Axis height.
![Set-of Ten Straights.png Set-of Ten Straights.png](https://www.hobby-machinist.com/data/attachments/325/325354-4dc85d14e7cea726ba2672779be49adf.jpg)
Of course, I be the guy who bought 105 so-called "cobalt" drill bits that would disgrace even the rust they will end up as in the landfill, so if the deal looks too good to be true, it probably is, but this is not about pricing. I want to know what you experienced folk go for when choosing reamers.
I see also "adjustable" types. How good are they?
