- Nov 8, 2011
- 1,678
I really need some help here, I have all the mechanical & bracketry pretty much covered but I know zero about what I need in the motor/driver/electronics to complete this thing. This guy owes me pretty much everything I need in that area but he mostly has high end stuff for servo motors. http://stores.ebay.com/BANNER-DISTRIBUTING If any of you care to do a search and see what he has that I may be able to use I'd highly appreciate it. If he has nothing I can use I can just take the balance of what he owes me in other junk he has at his warehouse.
I took the servo motor off of the linear slide I have to see if one of the steppers I had would work but the hole pattern was off a smidge and the shaft needs to be longer (things I can fix if need be)
What I want/need is a 4 axis setup with as big a motors as possible as I want to be able to mount a router and do some light milling in aluminum as well as wood. I need to get this stuff ordered while I have the money. Somebody Pleeeeeze help!!!!!!!!!!!!!!
