I'm trying to get a RATTM MOTOR 4 Axis TB6560 controller board working correctly.
I have started a new thread for hopefully some new input on the situation.
Here is the system I am playing with:
It seems there are issues with the controller board and the range of settings in Mach3.
Changing the pulse width down to anything less than 5 is hopeless.
I sure would like to try 6...
Looking at old (2011) web info on the 6560 driver chip suggests there are timing
issues. The info suggests it runs better with LinuxCNC than Mach3.
Anyone using this board with success?
DW
I'm looking for CNC3020-800W info
A New guy here. I picked up a used Jing Yan Instruments CNC 3020-800W engraver/mill that seems to function OK. it has a JY5800 controller. The controller has a parallel port AND a USB port....that suggests I can use the USB port instead of the parallel port?? Looking for software and...
www.hobby-machinist.com
DW
