- Aug 29, 2019
- 1,139
Attached is the interface for my Blue DRO. This one I installed on my PM Mathews 833T about 3 years ago. Well I decided to use the little mill today since it already had the Boring Head in the spindle and the BP-Clone has a 3/4" end mill in it. Gona save some time right? I got the spindle centered on the hole I wanted and was all ready to bore it to depth. And wouldn't you know the Z -Axis was not moving at all when I would move the spindle up and down. After several dirty words I launched on a thorough investigation of WHY NOT! The Z was not working because the usb female connector on the board had been damaged. The old interfaces did not come with a good way to anchor them so it did not get anchored. Attached are a couple of pictures of what I found. I am going to try my luck at re soldering the connector and see if this works. If not I may just use one of the battery powered displays that came with the I-gage set to read the Z position.
