- Dec 23, 2019
- 1,138
Hi folks
I'm undertaking a tool grinder build. I've followed up several excellent suggestions for previous projects and plans, and come to the conclusion an air bearing for the work holder would be nice. More detail on why in my build thread when I update it shortly. I've got a precision ground shank for the work head, so I'm now looking at how to make the bearing pads. The most successful designs seem to use graphite, which is cheap and works extremely well, but I'm having some trouble tracking down graphite blocks (that don't come on the slow boat from China) to work with, so wondering if anyone has experience with constructing air bearings in general; particularly using other materials.
Its a bit of a case if "because I can and its interesting". I'm sure oilite or cast iron bushings on the shaft would work fine, but I've done that hundreds of times. The air bearings are particularly attractive because the air keeps grinding dust away from a critical area and you get super low friction and great precision. Just to be clear, we're talking about forcing air through a porous material bearing against a precision ground shaft.
I'm going for a ball bearing main spindle to begin with, but if the work head is a success I'll look at setting that up on air bearings too.
