R8 Collet Grip Range
HarryJ
Mar 9, 2021
21
I have a Grizzly spring loaded tap guide which is supposed to have a 1/2 inch shank, but it measures 0.495. Will it damage my 1/2 inch R8 collet, if I install the tap guide in the collet? What is the recommended grip range of a 1/2 inch collet?
It won't hurt your collet. But 0.495 is a bit light, and I wouldn't go much less. Normally R8 collets want on-size tooling, but I can't find a spec anywhere.
An R8 collet with .04" slots will typically grip about .05" smaller than the nominal diameter so a set of collets by 1/32" or 1mm for metric will grip any diameter shank within the range of the set. I tend to use collets on my mill rather than a drill chuck for holding drills and I have on occasion pushed that 1/32" undersized pretty hard. I have never seen an issue with a collet as a result.
That said, a collet only grips full circle at the nominal diameter. Anything smaller results in a three point grip. Additionally, forcing a collet to grip smaller than nominal results in a distortion on=f the spring portion of the collet. In order to properly mate with the collet socket, this distortion will be S shaped. The greater the deviation from nominal diameter the more pronounced the S shape will be.
I have a set of R8 collets by 1/32nds. A near as I can tell, R8 collets are only available in 1/32" increments for inch sizes and 1mm increments for metric sizes. The implication to me is that they are designed to be used for shanks that are under nominal by that amount.
