R8 adapter?
I've never seen one. You may be able to get a 9 or 10 to 7 B&S sleeve and turn it so you could use it in a R8 endmill holder. If you have an R8 taper in your mill and a lot of #7 B&S tooling you might just want to sell it and buy what you need. When you have tooling sticking way out of the spindle you loose a lot of Z height. What do you have to work with?
Thanks for your reply. I have a Bridgeport and I think you are right about the length issue.
Maybe you could turn straight shanks on the B&S 7 tooling...........
