Okay, it's a done deal. Things I learned, replace ALL the bearings and the belt when you do this. You don't want to go to the trouble of taking all the gears off, the guards, disconnecting the electrical, and taking the headstock off but once. Plus the putting it back together and re-aligning the headstock and tail stock. The bearings for the back gear assembly are common size(1"OD by 3/4"ID and 3/4"OD x 1/2"ID) oilite ( or similar) bearings. They're cheap so replace them all. The main bearings can be ordered using the numbers on your old bearings. The bearings in the spindle cone (there are two and both are 1 7/8" ID) are (at least on my machine different OD's. One was 2" OD and the other was 2 1/8" OD. I ordered these from Logan. They are oilite sleeve bearings, 1" in length. The belt for my 11" Powermatic is a 520J16 micro groove poly belt. The 520J is an industry standard number. The "52" in the number is the length of the belt. The "16" is the number of ribs. Whatever brand belt you buy, the number will be the same. I bought a Gates brand poly v belt for $39. You can get the Logan belt from logan for $159. Before you put the headstock back on the bed, install the spindle. I used a piece of 1/2" all thread to install the spindle back into the head. I bought a 6" piece of 2" cast iron pipe and an end cap for it. I drilled a 17/32" hole in the cap which I ran the all thread through. This goes on the left side of the headstock, the all thread through this adapter and through the spindle. Tightening up nuts on the ends will draw the spindle into the headstock. By putting the spindle in while you have the headstock off the machine, you can align the back gear to the spindle so the gears will mesh properly and are in line. Also, after the spindle is installed, turn the headstock upside down and install the back gear rack lever. It is a helluva lot easier than trying to install it once the headstock is back on the machine. You can get the back gears to fully engage and mesh this way and adjust the rack lever to where it does that perfectly. If anyone does this and has questions, contact me.
